I have a K75 that needs a replacement finaldrive, would a K100 fit ! Anyone know where there maybe one.Thanks for any help
robinm1,
Feb 5, 1:12pm
Depends on the exact spec of the K75, if it is a disc brake rear one then a final drive from a '86-'90 K100 will fit, the ratio is slightly different, but it will work ok. If your K75 has a drum brake on rear, then you need a diff from a drum brake K75, very hard to find. I have lots of K parts here, but no good final drives, they are getting very hard to find now. What is wrong with yours as bearings etc are available ex UK or USA.
ova53,
Mar 13, 2:42am
Thanks Robin for youre response, my bike is 86s model , being disc. Bikeshop was replacing bearing ,which we had but found other wear whichI am not sure name of part . It is alloy with a taper .All gears are OK .Shop seems keen to replace with another diff
