can anyone tell me why my abs light is on in my bmw, i have checked fluid level and all is good! cheers
Dec 15, 5:24pm
Most likely a bad connection somewhere. It can also be a faulty sensor, pump, or the control unit.
Dec 15, 5:26pm
My work vehicle, Mazda Bounty had an ABS light come on when I lost traction on a farm once. It took around 15 km of driving to clear itself.
foxdonut,
Dec 15, 5:46pm
Your brake pads are due for replacement
You have a tail light out.
saxman99,
Dec 15, 6:26pm
The light means your ABS computer has detected a fault somewhere in the ABS system. You will need the fault codes scanned from it by a garage with a BMW compatible scan tool. This will hopefully tell you which bit isn't working and the garage can advise on the best course of action to remedy it. You will fail your next WoF if the light is still on.
Good luck!
mm12345,
Dec 15, 6:49pm
BMW abs light. oops.Yeah - good luck. If you believe in the power of prayer, start now.
wasser61,
Dec 15, 7:30pm
And nice bank manager who can organise a hefty overdraft to pay for the repairs.:)
suplyuparts,
Dec 15, 9:30pm
BMW 318.!,thats the problem.
jasongroves,
Dec 15, 9:51pm
Read much!
shinra,
Dec 15, 10:43pm
better to just disable the light instead of looking for the problem(what problem.)
saxman99,
Jun 10, 3:55am
Brilliant advice there.
It will still fail the WoF if the light doesn't work at all.
