Nissan crankshaft
goron56, Dec 19, 3:14pm
Anyone know if an SR20DE crank is the same as a DET,and are front wheel drive sr20de shafts the same as a rear wheel drive!.reason.i have a DET shaft that needs ground and i know of a DE shaft thats been ground, crack tested, and acid washed i can get for nought, they look the same,just want to be sure,cheer's.
falcon15, Jun 20, 5:06am
sr20de/det rwd crankshafts are the same but a fwd/4wd crankshafts are different
