Xr6 versus xl ute
ksam, Feb 15, 4:50pm
can anyone tell me what differences there are between these two utes, is it just the cosmetic stuff or are the engines and suspension different! Keep it simple, I'm only a joiner!
dr_blueoval, Feb 15, 5:10pm
Suspension is harder and has more aggressive settings on XR's, in conjunction of course with a different wheel/tyre package. The SOHC 4L engines in AU XR6 utes have slightly higher power/torque output than the standard Intech fitted to an XL/XLS, some also had VCT which were slightly higher again.All normally aspirated BA and BF have the same output regardless of the model, you had to buy an XR6T if you wanted more power.If you want the three seat/column shift option this was only available on XL.
fordguy17, Feb 15, 7:03pm
That plus the XL ute looks like a Futura (basic styling) where as the XR6 has a body kit, different headlights and bumper, fancier interior trim etc etc.
ksam, Apr 23, 12:08am
Shite Dr blue, that was better than google, just guessing, you're a Ford fanatic! Thanks for the response boys.
