HT Holden clutch master cylinder seal kit
mk3zephyr, Feb 18, 8:13am
Anyone know where i could get a seal kit from!, BNT!, If anyone knows are the HT/HG ones the same as an HQ-WB! or did they run a cable system (cant remember). Did a google search of the numbers off the master cylinder and came back as an HT Holdunga (the fact that it has "Holden 7433521" stamped on it helps a bit), and the picture was the same, Is also a PBR type as the seals inside has it stamped on, recommendations anyone!
mike107, Feb 18, 8:17am
Holden dealer parts department!
intrade, Feb 18, 8:27am
i get my seal kits from owens suspension whangarei and he orders em from auckland. they can get seals for anything just need the numbers on the seals. used to cost bugger all. done all brake seals on 73 hanomag merc for 50$
sr2, Feb 18, 8:29am
From memory the HQ was cable clutch (the large single diaphragm Mastervac took up too much room to fit a clutch m/cyl on the firewall). Not sure about in NP but Kevin at ABC Automotive Brake & Clutch (30 Barrys Point Road, Takapuna, Auckland, 09- 486 6992)should be able to help with the seals.
mk3zephyr, Feb 18, 8:34am
no, dont be silly
skin1235, Feb 18, 1:01pm
either get the numbers off the old seal or take the master with you, just wandering in with the seal and no numbers or a fixed measurement will not get you what you want, they were very common, I recall that trogan used the same master in the early days
elect70, Feb 18, 1:39pm
BNTcheap as chipsjust be certain cylinder isnt worn,can get them SS sleeved & recon for around $150
mk3zephyr, Feb 18, 1:48pm
got a kit, bnt didnt have a kit but was $38 overnight, found a kit at a local brake and clutch outfit $20.
saki, May 1, 12:54pm
Just go to a brake specialist get the cheap taiwanese ones replace every season used them for my rx3 race pedalbox no probs.
