Help!. Automatic car not turning overmaking a clicking sound and i can39t compress the brake which from memory i should be able
sharee9,
Jan 6, 1:07pm
Automatic car not turning over.making a clicking sound and I can't compress the brake (which from memory I should be able to do!) Any suggestions! Car is in 'park'. Toyota Gaia 2001 TIA
twink19,
Jan 6, 1:14pm
starter motor,battery
sharee9,
Jan 6, 1:22pm
any other guesses! I used the car this morning.if that helps
sharee9,
Jan 6, 1:24pm
Oh and interior lights work, if it's the battery they wouldn't aye!
mrfxit,
Jan 6, 1:24pm
#2 or battery connections-cables loose/corroded /fractured
sharee9,
Jan 6, 1:26pm
*runs to check connections*
mrfxit,
Jan 6, 1:27pm
Starting a motor & running lights are 2 very different voltage/amps requirements.
Battery on my truck would turn the engine over but couldn't get the engine to fire = battery stuffed for diesel usage. Same battery in a v6 Mitsi starts it first time everytime
sharee9,
Jan 6, 1:34pm
It's not going to fix itself is it. :-(
So a jump might help!
sharee9,
Jan 6, 1:35pm
Oooh oooh *remembers Roadside Rescue*
Jan 6, 1:49pm
jumper battery and see if it starts
Jan 6, 1:50pm
sharee-if you have access to another car I have a jumper pack you could borrow.
sharee9,
Jan 6, 1:52pm
I do have jumper leads but no other car. I'm just having lunch then will ring roadside rescue, guess I've paid for it might as well use it. But thanks very much for the offer kazbanz!
sharee9,
Jan 6, 4:28pm
It was the battery.(can't even blame the kids for that one - lol) Thanks peeps.
3962,
Aug 16, 12:10pm
That really depends on how old they are. Old enough to want to listen to the stereo, its their fault. too young to understand the music of today, their fault because they don't sit straight in car lol. My kids I used to wonder why sometimes the electric windows wouldn't work. I'd have them clapping/whistling, saying window up/window down, very amusing back then. Now I get told "well, you weren't meant to be having fun at our expense. those were the days.
