Grinding wheel
jono2912, Feb 27, 3:18am
1991 Camry ZV
Wheel makes grinding noise when braking, but only at very slow speeds (under 20kmph)
Where do I start looking!
Front left wheel.
afer_daily, Feb 27, 6:14am
brake pads or shoes ! how long have you had it /how many Ks have you done!
stevo2, Feb 27, 6:26am
Brake pads need replacing, since its been left so its now metal to metal, you may need the discs skimmed as well. Allow $400-$450 if getting it done by a workshop.
Cheers Stevo
lookoutas, Feb 27, 6:37am
Could be a stone. Back up and see if it dislodges.
gtrnut, Feb 27, 10:51am
yes sounds like front brake pads down to metal-if disc rotors have been scored they may not be machinable or they may go below minimum thickness once machined which will mean they will need to be replaced also-you can go aftermarket or genuine toyota disc rotors
johnf_456, May 31, 3:49am
If your lucky it will just be the wear indicators if you change them in time. Find a mate or a friend of someone depending on the car will be way cheaper than a mechanic. I changed my neighbors ones he got brand new rotas and pads for 100 bucks on his familia.
