'94 sedan, 2.5L petrol, 5 speed automatic. Left hand headlight not working. Have checked fuses all seem good. Bulb good too. Thank you all.
a18a,
Jan 10, 12:58pm
You're welcome.
budgel,
Jan 10, 1:52pm
Follow the wiring back from the headlight until you get power. Or run a new wire from the relay and one from the headlight to earth.
jsbike,
Jan 10, 3:14pm
there is a large relay in the engine bay, on the drivers side strut tower, I "think" its brown, check its contacts/give it a wack.
skull,
Jan 10, 3:44pm
I had one of those, it turned out to be a broken solder connection on one of the relays that #4 describes above. From memory I think I had to solder it from the underside of the PCB.
henderson_guy,
Jan 10, 3:47pm
Corrosion on the bulb/plug contacts.
jjc09,
Jan 10, 8:15pm
Very common fault in those 9/10 times its the brown relay
budgel,
Jan 11, 11:10am
Do they have a separate relay for right and left sides!
the_don_61,
Jan 11, 11:33am
Nissan also have a fail safe in headlight switch.
when switch dies left hand head light doesnt work.
Headlight switch needs replacing if fuses are fine
ottoitis,
Sep 5, 12:02am
To all the above, thank you. Light now fixed. Was a wire in the relay that the auto electrician soldered. #4 was the closest/correct.
