Headlight buzzer
jono2912, Mar 17, 5:42pm
After recommendations.
Needs to be:
Cheap
Quality (I know, I know.)
Easy to install (The easier to install, the more I will be willing to spend)
This is for a package deal (product and install), so therefore, wholesale purchasing would be better than retail. Jaycar only have the kitset version.
Cheers
aredwood, Mar 17, 7:53pm
Easier just to rewire the headlight switch so the lights only turn on when the ignition is on. Impossible to leave the lights on that way. Or just wire a small buzzer between the tail lamp wire and ignition with a diode in series so when the tail lamp wire is live but the ignition off the buzzer will then sound. The diode stops the buzzer going when the ignition is on but the lights are off.
morrisman1, Mar 17, 8:14pm
another way is to have a buzzer powered by a dashboard light but have the circuit broken by a relay (change-over relay) and the relay breaks the circuit when the ignition is turned on
glyn4, Jul 29, 11:01pm
What size/power diode or relay would you need for the circuit! Sorry I'm an electrical moron.
