Where do i find the spark plugs
plc68, Jan 27, 7:04am
in a subaru impreza wrx 1996
gadgit3, Jan 27, 7:18am
DOHC or SOHC!
gadgit3, Jan 27, 7:19am
Either way there in the cylinder head but DOHC are slightly harder to get to.
saki, Jan 27, 7:36am
If you are unable to find them without help there isnt much chance you will be able to change them.
crzyhrse, Jan 27, 7:56am
Through a hole in the head to the combustion chamber unless it's been converted to external combustion!
I'll say.
owene, Jan 27, 8:05am
They'll be under the passengers seat inside the rad box marked "SPARKES".
plc68, Jan 27, 9:05am
Im a girl im not doing anything, but i got told that who ever does it will have to drop the motor
plc68, Jan 27, 9:06am
WTF!
gadgit3, Jan 27, 9:10am
No Motor stays in car. If they want to drop the motor then you find another mechanic. Depending on what model you have it should take up to an hour to fit plugs.
jsbike, Jan 27, 9:10am
bull, they are a mongrel to do if you have big neanderthal hands but no way do you have to drop the motor. how much did they quote you to do them!
electro2000, Jan 27, 9:49am
pretty easy to dosometimes air box out one side battery out the other , i cut a rachet down and shortened an exstention just for subaru plugs-makes them pretty easy
pup2, Jan 27, 9:58am
First of all we had to remove the sump, then the crankshaft the gudgeon pins, the conrods then the pistons so we could take the spark plugs out
mugenb20b, Jan 27, 10:03am
Take the battery and air filter box out of the way. You'll see two wires going to each cylinder head.
happylad3, Jan 27, 10:19am
They were dirty.
thewomble1, Jan 27, 9:31pm
Put the new plugs in with the petrol.
n3d4sp3d, Jan 28, 1:28pm
see its wankers like that that give the motor industry a bad name
pico42, Jan 28, 1:42pm
What does being a girl have anything to do with it! Do you intend using your gender as an excuse for all things you don't know about!
plc68, Jan 28, 3:50pm
mechanic is a mans job!
tonyrockyhorror, Jan 28, 5:07pm
Then why even ask!
Back to the kitchen with you!
bopbargains, Jan 28, 5:41pm
all womenshould bechained tothebedroom,with justenoughslack to reachthe kitchen.
mugenb20b, Jan 28, 5:43pm
I dare you to post that in Parenting.
ryans, Jan 28, 6:43pm
I remember when motoring wasn't filled with people trying to make jokes and not actually helping.
plc: they are on the sides of the engine, between the engine and the side of the engine bay. If you do a Google search for "boxer engine" or subaru engine, you'll see the layout.
They are a pain to replace, but you don't need to remove the engine.
mugenb20b, Jan 28, 6:53pm
Yeah, a sense of humour does a lot of harm. We should all be serious around here.
russ18, Jan 28, 7:07pm
I sympathise with you, after over 20 years of diesels I now have a 3.5 litre Nissan elgrand. A few weeks ago I thought I would check the plugs and leads.
now know it doesn't have leads and with a bit of help from google I know where the plugs are but still haven't actually seen them.
