Oil temp.Subaru
20498, Mar 18, 4:12pm
Where would be the best place to put the sensor on a EJ20T!
Cheers.
ola_bitchola1, Mar 18, 4:16pm
T off the factory oil pressure sensor
nz.lover, Mar 18, 4:19pm
hey i have a oil temp Pro Plus 52mm Stepper Gauge, would that t off the factory oil pressure sensor! or would i need adapters!
20498, Mar 19, 7:36am
Is that the only place or is that the best place to install it!
Cheers.
matthew_129, Aug 4, 2:51am
If youve got a single turbo subaru there is a bolt in the rear of the passengers side head that is used for the oil feed on the twin turbo motors and can be utilized. Other option is drill and tap the sump plug and fit it in that
