Edit 4x101.6mmI think you might find vauxhall viva ones are the same and maybe there 12"
smac,
Jun 25, 6:54am
x1
Later minis ran 12's. I ran a set of Imp Sport 12X6's for a while on my Elf and then on my MKI.
Do you have a set of Imp rims looking for a home, or have an Imp with no rims!!
Keep in mind the whole FWD/RWD thing too, as this (usually) effects the offset of rims.
Edit: memory just kicked in. Although they are a 4" PCD, I THINK they used a larger diam. stud. This means there is technically a little 'slop' if you run imp wheels on a mini (taken up by tapered nuts, not ideal but no real issue IMHO), and mini rims may have to be modified to be used on an Imp.
mrfxit,
Jun 25, 7:06am
Fiat /Imp/ Viva & Victor had a very very similer stud pattern. Can't remember the exact bits now but as above, some had smaller stud holes & some had very slightly different Pcd's but would fit ok (something like a difference of Eg: 101.6 to 102.2 sort of thing) ** I think theres some of the more modern Mazda's that are about the same as well
^^ Viva and Imp are 101.6, as are Mini. Am unsure about Victor, I would have thought they were 5 stud. Older RWD Mazdas were 110 or 114.3 and newer FWD Mazdas are 100 or 114.3.
mrfxit,
Jun 25, 8:11am
Victors are 4 stud regardless of engine You are thinking of Cresta's which are 5 stud which only have 6 cyl engines
tigra,
Jul 23, 11:06pm
Morris 1100!
