Adjusting park brake, VY Holden Ute
gmnshprd, Jun 9, 9:39pm
Ute just failed wof as the left rear parkbrake needs adjusting.Is this an easy job to do or will it be best to take it to a mechanic!
phalanax, Jun 10, 8:49am
If its like the sedan it can be adjusted from the handbrake lever which is worth a shot as a quick fix . however because its failed on one side its probably worn the shoe more on that side.its a disc shoe combo (they have been known to drag shoes).probably best to get a mechanic onto it.
gmnshprd, May 26, 5:12am
Thank you for that, they have noted that the brakes are starting to wear.will get it in to get sorted.
