recently got all new spark plugs, air filter and oil and filters replaced in our mits legnum, car was going fine before hand and now it shudders on accleration and the engine light is on. Any ideas on what is wrong! HELP
Jun 6, 4:31pm
If its a GDI it could be anything.Get set for even more of a financial drain.
indi301,
Jun 6, 4:37pm
No not GDI just a standard v6 2.5 litre triptronic
muzz67,
Jun 6, 4:42pm
who did the work! Workshop or home job!
for_an_angel,
Jun 6, 4:47pm
One or more of the spark plug leads could have been damaged when removed. It would be my first check. The cap of the plug can sometimes get well seazed on to the lead end seen as the plugs only get changed every 100000kms, and if your not careful when removing you can pull the lead end off the lead which would result in a shudder
indi301,
Jun 6, 4:57pm
would that make the engine light come on! It was a back yard job but he a good mechanic. But he did tell me to get the engine light fixed it will need to be scanned by a sparky! Who pays for that, it was fine before!
biddy6,
Jun 6, 5:06pm
Definately start by checkingthe leads, my engine light came on when one plug lead gave up.
Jun 6, 5:08pm
He may have just left an electrical plug or a vacuum hose disconnected.
indi301,
Jun 6, 5:12pm
Thanks for all the comments, will go back 2 him tomorrow. BLOODY CARS!
im_andrew,
Jun 6, 5:18pm
BLOODY BACKYARD MECHANICS!
lugee,
Jun 6, 10:12pm
Bad or damaged ignition leads will cause a Check Engine light, because that cylinder will be mis-firing which will be detected by OBD-1 or higher systems.
marmatt,
May 15, 6:09am
plug gap too
