Would snow chains help us get outta these situatioins of being stuck!
jezz43,
May 29, 7:24am
planks of wood wouldnt hurt. place them under the drive wheels and it should be ok
jason18,
May 29, 7:40am
Yeah we thought of that too. Will bring some wood with us. Cheers Mate
May 29, 8:09am
You can get more traction by lowering tyre pressures too, but you'll need a small portable air compressor to reinflate the tyres afterwards.
serf407,
May 29, 11:40am
What is the tow vehicle and is it 4x4 etc ! Mud tyres are a primary consideration. Mud chains can be custom made. Then dual wheel combos. Then air lockable diffs. etc
mrsdoobercoons,
May 29, 11:51am
Can you winch, or tow it in with a strop from a firm location.
Chains will help in mud until you start digging a hole with them, then you have a problem.
jason18,
May 29, 12:30pm
Ok cheers guys, We had a 2wd ute which was usless but now have a falcon wagon which is probably more useless haha.
m16d,
May 29, 12:32pm
Borrow a tractor
May 29, 12:35pm
Try leaving the strop as loose as possible, and "launch" the ute as fast as you can. Don't use a tow ball or non rated D shackles.
jason18,
May 29, 1:19pm
got rid of the ute now. What about a winch that we could hook on towbar to winch cherry picker out!
pico42,
May 29, 1:39pm
Yes, they would - I am assuming it is a greasy surface type mud.
jason18,
May 29, 1:49pm
yeah its a car wreaking yard. Quite muddy,
