Subaru legacy timing
minimad78, May 25, 7:27am
Hey there. My legacy had a dead distributor. I just replaced it and now it doesnt want to time up. i've tried all the different distributor positions. The best i've got it to do is turn once, and kick back. All the leads are on the right spark plugs, etc. so we can rule that one out. Any help out there!
ginga4lyfe, May 25, 7:31am
set at top dead center and see were the rotor points! it can kick back if the dizzy is out 180 degrees
minimad78, May 25, 7:37am
Sweet as. How do I tell if its at top dead center! these boxer engines confuse me.
ginga4lyfe, May 25, 7:44am
welll. hmm i havnt worked on them myself, but i would find out which is the no 1 piston, then find out when its on its compression stroke(top of compression stroke ), then just look at the pully on the front of the engine to see when it is supposedly at the tdc,may be hard to find out when its on compression stroke on some engines if they are inthe car, but since you say that it has a dizzy i woud imagine that you are working on a ea82 or similar engine, which makes getting to the spark plugs and poking a screw driver in the bore to find tdc alot easyer if the rotor isnt pointing to no 1 plug lead once the engine is at tdc then remove and re install to as close as you can get it, which is annoying if the teeth are on an angle
minimad78, May 25, 7:53am
Sweet thanks man. I'll give that a go this arvo and see how that turns out. fingers crossed i can get it started. its been off the road a month now and im sick of walking everywhere haha
ginga4lyfe, May 25, 7:55am
haha, i know what thats like with my triumph being unpredictable, im almost ready to drop this for a subaru legacy
minimad78, Mar 30, 7:54pm
Subarus are unreliable. I've spent more than its worth fixing it haha. They're pretty quick though (when they arent blowing turbos or clutchs)
