hey guys. can any one point me in the direction of a diagram of how to plumb up a bov in a subaru legacy wagon. single turbo.
tia
elshaun,
May 23, 1:16pm
Please don't take offence Christina, but WHY!
twink19,
May 23, 1:25pm
wof regulations, must be plumbed in now
anarky,
May 23, 2:06pm
Firstly exactly what are u trying to do,These cars come with a BOV from factory so should not need another different one :) if it has an aftermarket one that is vent to air and u want to plumb it back then you need to look at the pipe that goes from your airbox to turbo for a blocked of pipe about 19mm in diamtre this is where it plumbs back into. For more info goto www.clubsub.org/forum sign up and do a search has been covered a fair bit
hijacka,
Mar 25, 2:42am
And why would you vent measured air! Unless you run a link ecu so you can ditch the afm and measure air via the mapsensor don't do it, also dont go banging a pod filter on it either unless you want further afm problems.
