One way air valve
jsbike, May 20, 6:37pm
where can I get or what could I use as a one way valve for air! it needs to let enough air through to an idle control valve to control idle speed on my motor. When it hits boost (supercharger) and the manifold pressure comes up, it needs to close so the boost pressure is not expelled out the idle control valve.
unclejake, May 20, 6:45pm
Would an adjustableblow-off valve be too coarse in its pressure range!
jsbike, May 20, 6:51pm
yeah it needs to have near no resistance when the engine is sucking in air.
sred69, May 20, 7:50pm
clark20, May 20, 8:34pm
Like a large PCV valve or the one that goes to the brake booster!
sr2, May 20, 8:38pm
I'd do it electronically with an idle control valve from an injected motor. Should be easy to build it a simple circuit controlled by a pressure switch.
zephyrheaven, Mar 14, 4:56am
Have a look thru some later model washing machine plumbing, very handy for oil to air separators & electronic solenoids way over engineered for simple automotive use - there is one in a gentle annie like you speak of from memory, in line switching low voltage etc.
