Only 4! Are you sure these are faults or is it listing the things that are still working!
steve-007,
May 20, 4:59pm
didn't you just answer your own question! as you have the codes and their descriptions.
bigfatmat1,
May 20, 6:50pm
You should clear them road test and re check codes before ya get to carried away.
vag.central,
May 20, 8:43pm
Hall sensor is in the dizzy, check the plug an wiring, although if the car is running fine I wouldnt worry about it
vag.central,
Mar 14, 3:07am
then I would be checking out the hall sensor and wiring
