Hi i've got a SR18DE 1990 Nissan Pulsar, Occasionally the electrics stop working and i cant start the car. The interior light is on, but no dash lights. Its cut out on me while driving and randomly fixed itself!
Any ideas anyone!
Cheers
tmenz,
Jul 3, 8:04am
Sounds like a poor fuse or connector contact somewhere. Try removing all the fuses - one at a time - check for corrosion on the contacts and clean if necessary - then replace them.
danni_2254,
Jul 3, 8:35am
Ok thanks, will check now.
pandai,
Jul 3, 9:19am
Sure it's not the key ignition switch!
ola_bitchola1,
Jul 3, 9:37am
id be checking battery connections also
danni_2254,
Jul 3, 12:52pm
Battery connections OK - brand new battery also. Will check key ignition also,
Thanks =]
grangies,
Aug 23, 5:10am
Faulty ECU! (engine computer)
