Need help with u13 4wd manual turbo!
hoonin, May 12, 7:55pm
Ok so have a u13 manual 4wd, sr20det running 250kw at the flywheel. Just spent 7k on motor, and third gear blows up. This is the third time the gearbox has failed me and i cant get hold of another one. so need to know if i can put in the bluebird center diff into a gtir gearbox as the gtir runs different center diff ratios which will lock up the rear diff. Any ideas!
hijacka, May 12, 7:59pm
Its not the centre diff that failing you thou. What type of clutch are you running!
morrisman1, May 12, 8:26pm
you spent 7k on a bluebird!
jsbike, May 12, 8:45pm
only 7000rpm! took 9000rpm to blow my nissans front diff. was making some quite "interesting" engine noises by then though lol
bubbles244, May 13, 1:46am
if you spent 7 k on the engine you might as well spend 7 k on straight cut dog engagement gearset.
or just buy a car that can handle the power.i.e. skyline
hoonin, May 13, 5:18am
i realize its a weak box and yes ive spent big $$ on this car mainly cause i didnt want skyline or evo like everyone else. on my third clutch now from autoclutch and they are not being helpful at all so going to a exedy one which will handle the power but my real question is can a u13 center diff fit into a gtir housing so i can use the complete gtir box.yeah i know its the gearbox that is failing me but i need it back on the road and i cant find a u13 box
rbjz, May 13, 5:35pm
5 points
dent, May 15, 8:32pm
so dont get a clutch that is to strong. You want your clutch to be the weakest part not your gearbox and unfortunly they arnt that strong.
johnf_456, Feb 22, 11:06pm
Get a good clutch
