i have a subaru legacy 2000, non turbo that has just started slipping/popping out of gear while reversing,It has only does this twice so far in the last two days, What would be the most likely cause! it is a 5 speed manual
thanks
johnf_456,
May 13, 5:42pm
Checked the trans fluid!
May 13, 5:54pm
It's 5 speed manual John!
johnf_456,
May 13, 6:05pm
Still should check the fluid, whos to say there was not a leak. With gearbox issues the easiest thing you can do is make sure they have the correct fluid and topped up before going head first in the deep end.
May 13, 6:06pm
And lack of fluid will make it pop out of gear.how! I was going to suggest to check all the gearbox and engine mounts first.
johnf_456,
May 13, 6:08pm
Still something that should be checked even part of maintenance, if the mounts were loose there probably would be a bit of a jolt / shock in the car which the OP has not mentioned.
mandie5,
May 13, 8:10pm
the car was serviced last week as per mechancial warranty services so all fluids wouldve been checked and topped up when it first slipped out,i had thought, that maybe i had put it in neutral instead of reverse but it happened today as i was reversing out my driveway
johnf_456,
May 13, 8:12pm
Perhaps take it back to them, if they did the work they would know what has been done.
mandie5,
Feb 15, 1:47am
ok thanks, i am going to ring in the morning but thought id ask on here for tonight,never had it happen before thanks anyway
