Thin steel plate between engine and gear box!
peekaboo4u2, Dec 12, 4:56pm
hi people whats the steel plate between the engine and geabox called! i thaught it was called a sandwich plate or dust plate but doesn't show any when i surch for one on here. im needing one for a 350 chev- th350. cheers
mottly, Dec 12, 4:58pm
we always called them sandwich plates too.probably got some weird tech name!
crzyhrse, Dec 12, 5:04pm
Spacer plate!
rover79, Dec 12, 5:05pm
Are they actually a spacer or an adapter plate!
peekaboo4u2, Dec 12, 5:08pm
all they do is stop dust and stuff getting into where the fly wheel- flexplate is. thanks for replys
peekaboo4u2, Dec 12, 5:11pm
probly should say tin plate
crzyhrse, Dec 12, 5:16pm
They don't adapt anything - the holes match without them.
mk3zephyr, Dec 12, 5:20pm
yea my 350 in my racecar bolts up to a 3 speed chev box and there is no sarnie plate there,, just made a bolt on cover at the bottom to keep the dirt out of the clutch dept
peekaboo4u2, Dec 12, 5:26pm
mk3 yea thats what i was going to do if i couldnt find one.
whqqsh, Dec 12, 5:44pm
Sandwich plate is the one Ive always used & heard
peekaboo4u2, Dec 12, 6:06pm
surch lol search*
mm12345, Dec 12, 6:31pm
So why are these spacer plates usually made with a cut-out for the flex plate or flywheel smaller diameter than the flex plate!
Serious question - as if there isn't a rational answer, then they obviously just did it this way to be an utter PITA.
mk3zephyr, May 29, 9:47pm
Just a couple of bolts holding it on and it isnt such a PITA to remove and replace if you have to
