My Ute has started smelling of Sulpher
spudster, May 9, 3:00pm
I have a 99 ford courier and it has started to give off a sulphur smell. Does anyone have an idea what might be causing this! You can smell it coming through the A/C. Thanks
attitudedesignz, May 9, 3:06pm
Cat' converter shitting itself.
spudster, May 9, 3:09pm
Can you punch the centre out!
intrade, May 9, 3:12pm
check your oxigen sensor is not faulty . as first action.
cat converter stinking means its working fine. you have the above problem or you simply drive like a nana and the cat cant get hot enough to clear it self good.
http://wiki.answers.com/Q/How_can_you_tell_a_catalytic_converter_is_bad
40wav, May 9, 3:13pm
This could also be your battery over charging. Had that happen in a loader and it smelt like sulphur.
franc123, May 9, 3:14pm
how about we establish first if its petrol or diesel!
barrie2, May 9, 3:15pm
So does mine - but I live in Rotorua.!
spudster, May 9, 3:15pm
Petrol
intrade, May 9, 3:17pm
yea well if its stinks out the exhaust then I be going for a warmup and a good thrashing at 5 high rpm to get the cat redhot glowing. then see if problem is gone if not next step oxygen lambda sensore on petrol engine is to be inspected and tested.
40wav, May 9, 3:24pm
Fair comment, but if it stinks at the battery its probably the battery.
intrade, May 9, 3:26pm
yup then you be getting the multimeter out and mesure what it charges at probably 18 volts to boil the battery instead of 13.8 to 14.5 volt
spudster, May 9, 3:27pm
It does seem to be smelling in the engine bay.
spudster, May 9, 3:28pm
I will grab a multi meter from work tomorrow. Cheers
bigfatmat1, May 9, 4:38pm
stuffed battery, or overcharging, are possible causes
likit, May 9, 6:15pm
Had the same problem,check your battery.
johnf_456, May 9, 6:18pm
Any sign of battery acid everywhere!
spudster, May 9, 6:58pm
A little bit of liquid on one of the caps. I have talked to a auto electrician and he said it could be the regulator in the alternator or the battery. Thanks
supernova2, May 10, 6:01pm
Nah you are all wrong, you've got a chick nesting and it's eggs are rotten
jrlaw, May 10, 6:23pm
Is it just me but when it is raining my cars cat smells a bit of sulphur, seems to be better after a long hot run as well.
richms, May 10, 9:47pm
Yup, as the battery boils, more and more comes out, it will cool down when you stop. Usually shagged when you can smell it but a topup of DI water will see them last longer than just ignoring it and not doing that. Get the charge circuitry sorted too or it will just keep happening.
budgel, May 11, 10:32am
I reckon it is the farts you got from the egg sandwiches you had for lunch.
richardmayes, Feb 6, 3:54am
Fibre man. Eat more fibre.
