Ever plan on taking that horse float off road (paddock etc)!
zooki007,
May 8, 8:13pm
Forget the commodore/falcon idea, you're going to require a landcruiser/patrol sized vehicle. Diesel would be better to tow with. Daily use would be bearable but not ideal though. You could just use the horses for daily use the way fuel prices are going.
ralphdog1,
May 8, 9:22pm
If it is going to be your daily driver and you are going to do more than say 10k a year diesel will probably be the answer. Me, I bought a 3.4 V6 Hilux, and only use it for towing. It was shitloads cheaper to buy, at the time probably 6-7k less than a diesel. And I dont get wacked heaps for Rego (licencing). But only do 5-6k a year and have something else economical as a daily driver. Falcondore will be OK until you drive into your first wet paddock.
NZTools,
May 9, 6:41am
Your estimate of 1500kgs is a little light too. A tandem float with two horses and gear is usually 2000kgs or a little over.
incedentally, add a vx landcruiser to that, and you are over 4500 kgs. You cant do that on a car license
berg,
May 9, 6:53am
Agreed NZTools. Most people hugely under estimate the weight of a loaded horse float. Sure they know what their "hayburners" weigh but they often forget the tare of the trailer plus all the sundry gear that goes along with horses. Yes a Commodore or Falcon will pull that sort of weight but on a cold wet road when it turns to custurd they just dont stop or handle a bad situation well. My sugestion would be Patrol, Landcruiser or truck. Also would suggest ringing your local CVIU and arranging a test weigh to sort out any legal issues.
mrfxit,
May 9, 7:04am
Agreed about the weight totals.
Average 15H horse would be about 550 to 700kg each Modern light construction double float minimum of about 300 up to 450kg empty JUST enough tack for both horses & a bale of hay each upwards of 100kg pair
So really anything from about 1.2T to 2.2T total
xs1100,
May 9, 7:11am
have a look at the other thread vechile for towing horse float why all you horse people want to tow all of a sudden
mrfxit,
May 9, 7:29am
OH & Falcons & commodores DON'T stop easily with 2T behind them. Been there done that
johnf_456,
Jan 29, 1:45am
Yip
