1990 Nissan Safari speedo sticking at 60
neell, Apr 30, 10:32am
Does anyone have an idea why the needle would stay on 60 when car is stopped. Even when reversing at slow speeds the needle goes to 60. I've had the dash out and the needle moves freely. Thanks
xs1100, Apr 30, 6:24pm
cable could do with some lube try crc tac too
mrfxit, Apr 30, 6:36pm
Most likely the tip of the needle has bent inwards slightly
If you tap the face , will the needle slip down again.
neell, Apr 30, 7:24pm
XS1100, no cable - thanks anyway
MrFxir, definitly no bend on needle - when you tap the face it will go either up or down, does both. Squirted some WD40 onto the unit but as it is a sealed electronic thingy I think I wasted my time doing so.
Thanks
msigg, Apr 30, 8:57pm
Its probably are poor soldered joint that is causing it, 8 years ago my safari speedo was going sometimes and other times not, took it out and to a place in newton Auckland and they fix a few of the soldere joints and from then never had a problem.
johnf_456, Apr 30, 9:27pm
Yeah, probably a dry solder joint.
poppajn, Jan 4, 1:17am
Probably at topspeed
