also temp and low fuel light stay on, I've searched and searched ,some say reset the ecu, some say common instrument cluster failure and needs replacement, and some even say it is a dud relay. arg. So ford motoring genius dudes, which is it. Guessing my speed ain't good for my blood pressure
vernunft,
May 31, 6:25pm
yip its an auto, and the gears are changing smooth as and seemingly at the right intervals fine, i'm also surprised at this with what i've read.
So should I be finding a "new" cluster or are they repairable.
Cheers for your time fish dude. :)
dr_blueoval,
May 31, 6:39pm
Is anything else in the instrument panel malfunctioning!audio, clock, heater controls or climate control if its a Fairmont or upwards model,, does anything change when the park/tail lights are switched on!If so I would be checking the cluster/dash ground connections before doing anything else.
vernunft,
May 31, 6:47pm
Hi doc. its a forte , so not many gizmo's
No tacho, no speedo, fuel light and temp light stay on,I have driven this in all conditions, nothing changes,
The fuel gauge, temp gauge & DTE work as they should. Tho i'm sure there was a hole in the tank when towing a well loaded tandem back from ashburton last week, lol
vernunft,
Jun 4, 2:27pm
bumping . full replacement of cluster or fixable!
twit7,
Jun 4, 3:34pm
we just had an au at work doing funny things in the dash ,turned out to be a bad earth
johnf_456,
Jun 4, 3:41pm
I would take it into your nearts ford dealer and check the earths, earths can do some really random as faults.
vernunft,
May 6, 5:15am
yes true, will chuck it on the hoist tomorrow and check earths, cheers john and twit (lol)
