Whats wrong with my car it sounds like a tractor
jojo.w, Apr 30, 7:03pm
was driving it today was fine then all of a sudden started roaring, has been a bit fumy last few weeks
jmma, Apr 30, 7:04pm
You ran over a Lion (o:
jasongroves, Apr 30, 7:04pm
Exhaust/manifold leak would be my bet.
morrisman1, Apr 30, 7:19pm
your 16 year old son cut off the exhaust to make mums car cool with the bros!
flagheaven, Apr 30, 7:24pm
allmassey fergusons sound like that !
jojo.w, Apr 30, 7:26pm
lol my 18 month old baby will probably do that when hes 16
johnf_456, Apr 30, 7:27pm
what sort of car and what has changed!
jojo.w, Apr 30, 7:33pm
toyota corona, was going fine today although has been a bit fumy last couple of weeks then i was driving into my property today and all of a sudden it started roaring really loud honestly sounds like a tractor
morrisman1, Apr 30, 7:35pm
Id put money on the exhaust breaking at some point, it happens.
get down on on the ground and with the engine running have a look around underneath, listening and looking for any breaks in the exhaust system. It could be as simple as a $20 weld or a bit more work may be required
johnf_456, Apr 30, 7:35pm
Possibly you have a hole in the exhaust, find a rag or something and put it over the tail pipe for a few seconds and see if it gets worse. and I say a rag as it will get sooty blocking the flow a bit should make the noise worse if there is leak / hole.
jojo.w, Apr 30, 7:39pm
ok awum thanks every1 i was worried it was going to cost me heaps, i will have a look at the exaust tomorrow.
jasongroves, Apr 30, 7:56pm
What year Corona!
Some of the late '80s models had non-cross flow design (intake and exhaust on same side of engine).
Stupid design and prone to fail and cause leaks.
Pain in the arse to get to and fix unfortunately.
Do as morryman suggested, but get a decent sized rag and cover the muffler/exhaust tip.
Will help you narrow down the source of the leak.
jasongroves, Apr 30, 7:58pm
Ooops. just noticed John posted pretty much the same thing.lol
jojo.w, Apr 30, 8:50pm
its a 1994 hope its not too hard to fix
pollymay, Apr 30, 10:23pm
Prolly a 3sfe or something, they go forever but sometimes the flex joins in the exhaust break and they rust.
jojo.w, May 1, 9:12am
mechanic had a look today the exaust has come away in the engine needs to be welded back on, cheers every1
johnf_456, May 1, 9:30am
Thought that was the case
kiwitrader43, Dec 30, 9:43pm
The fanhub/clutch may have seized up which will make a roaring sound under the bonnet if it has a fan/clutch. Usually on rear wheel drive older ones.
