It sounds like it's coming from the right hand side of the car, just a high-pitched squeaking noise sometimes as the cars moving forwards-had the brake pads and rotor pads checked and they're all fine. Any idea of what else it could be! Thanks
Apr 26, 4:42pm
Most likely a stone wedged in there somewhere or else one of the brake pad wear tags has hit the rotor, the pads might look like they have a few mm of material left on them but could still be low enough for the tag to scrape.At any rate you need to be double checking the brakes.
mattyandhiscar,
Apr 26, 4:44pm
So most likely the rotor pads yeh! Thanks!
jmma,
Dec 13, 5:46pm
Could be the brake pads (o:
