Clutch trouble. Ok where to start bought a brand new gbox for isuzu elf couldnt get into gear so had to shorten selector arm as
scoobeey, Apr 25, 6:06pm
ok where to start , Bought a brand new gbox for isuzu elf .Couldnt get into gear so had to shorten selector arm as chinese didnt copy too well!had flywheel machined . new spigot bearing .clutch plate is correct way around . new release bearing installed correctly.new slave cylinder. Bled .pedal hard. Clutch is not working. select a gear and start truck gbox workin ok just not clutch .clutch moves on spline okany ideas where to start
crzyhrse, Apr 25, 6:10pm
Not working as in won't engage or won't disengage!
crzyhrse, Apr 25, 6:11pm
Did you check the gearbox before fitting to make sure that when the input shaft is turned the output shaft turns when a gear is selected! I mean. it is chinese, right!
scoobeey, Apr 25, 6:41pm
x1
yes works fine
crzyhrse, Apr 25, 6:51pm
Then you've done something wrong that you think you haven't.
Don't worry about the other question.
crzyhrse, Apr 25, 7:06pm
It looks like this is one of those people who only answer part of the questions posed. I shouldn't bother if I were you, jmma. I'm not going to.
scoobeey, Apr 25, 7:07pm
wont engage so any ideas
scoobeey, Apr 25, 7:09pm
crzyhrse wrote:
It looks like this is one of those people who only answer part of the questions posed. I shouldn't bother if I were you, jmma. I'm not going to.[/quote
Ok dont bother pss off then
snoopy221, Apr 25, 7:10pm
Good start-STOP there.LOL.
I.E. was the original clutch left as same-and whay was the box bought!
snoopy221, Apr 25, 7:12pm
Lemme see where does one start! mmmmm new clutch covered in varnish and has drag/wrong bore size new slave cyl.mmmmmmmmmm!
Start at the VERY start-another box and problems!
I.E. was it JUST the box done!
scoobeey, Apr 25, 7:14pm
same clutch .Took off to have flywheel machined and clutch reinstalled. I did 250k in last box and was not productive to rebuild.
snoopy221, Apr 25, 7:16pm
same clutch .Took off to have flywheel machined and clutch reinstalled Damn ya scoobey i'm not programed for that-LOL-I.E. can't recall if the ole elf is a stepped flywheel.
Kapeesh!
jmma, Apr 25, 7:21pm
shaft jamming in spigot bearing, ie different sizes!
scoobeey, Apr 25, 7:26pm
no its a flat surface.
scoobeey, Apr 25, 7:29pm
yes something to look at cheers
crzyhrse, Apr 25, 7:30pm
You guys like playing hangman!
snoopy221, Apr 25, 7:30pm
Okay. so it is if i read right the ORIGINAL clutch plate! I.E. a new plate has friction material with grooves-a worn one can vacuum on to the flywheel a tad-problem seems to be clutch drag-and have struck this before from a contaminated clutch plate. Also worn plates with undrilled rivets can vacuum
again Kapeesh!
Understand!
scoobeey, Apr 25, 7:34pm
old clutch done 7000km had just done
crzyhrse, Apr 25, 7:35pm
Long time no hear, snoop-dog.
Now we can see why I asked.
snoopy221, Apr 25, 7:36pm
snoopy221, Apr 25, 7:37pm
Well that didn't work so AGAIN
perhaps a reword of the original post
I.E. just a new box! and no clutch drag problems prior!
snoopy221, Apr 25, 7:38pm
aye.
scoobeey, Apr 25, 7:43pm
sorry thats 70 k lol
scoobeey, Apr 25, 7:46pm
yes shortining selector arm sorted one problem as gearlever wasnt in windscreen lol.yes just a new box clutch wasorkin fine before
crzyhrse, Apr 25, 7:48pm
Presumably the box came with the clutch fork.
