2400cc toyota previa (mpv van)
trader127, Apr 18, 9:58am
Hi guys will this car be able to tow a car trailer and a 1.4 tonne car alright! Or will I need something a bit more powerful!
franc123, Apr 18, 10:01am
Providing you have a decent towbar rated for the job and if (and thats a big if) the cooling system is 100%, your trans is in good order and cooled properly, it should be OK.
thejazzpianoma, Apr 18, 12:13pm
Rated to about 1.6 Tonne braked with an appropriate tow hitch off hand. So you will likely be a bit over with the weight of the trailer.
As mentioned, done carefully as a one off you should be O.K.
But don't buy one to tow that regularly.
trader127, Apr 18, 1:20pm
Oh ok, yeah I will only be towing it from Auckland to New Plymouth, just this once. Would that be too far to go even as a one off!
thejazzpianoma, Nov 12, 6:56pm
Is the Previa properly maintained, especially with regard to the cooling system and transmission. as in right up to date, and both the transmission fluid and coolant looking the correct colour!
If so, and assuming you take your time and watch your temperature etc carefully then it should be O.K. It is quite a distance though.
