what service shops do you use in whangarei do have one that you recommend just a general service. have you had good feed back from them!
lookoutas,
Apr 14, 3:56pm
Cheap and good don't usually mix.
Apr 15, 6:18am
what carmake and model. new carshave high servicing intervals with expensive lubrications.
scousemouse,
Apr 15, 6:26am
just do it yourself.its not hard to change your filters and oil.
johnf_456,
Apr 15, 7:45am
Not always true
big.b-lil.c,
Apr 15, 11:55am
there is more to a service than that. but i must admit it's a good start
moosie_21,
Apr 15, 2:00pm
Just remember, there are 3 variables in play here, none of which can all be satisfied at once (unless you have enough mates to make up an extreme makeover crew.)
If it's fast and good then it isn't going to be good; If its good and cheap then it isn't going to be fast; If it's cheap and fast then it isn't going to be good!
a18a,
Apr 15, 2:09pm
If it's fast and good, why wont it be good!
lookoutas,
Apr 15, 3:17pm
Have you been taking johnf pills!
scousemouse,
Apr 16, 9:24am
thats about as good as you will get for under 300 mate,they only inspect your spark plugs these days and often only inspect your air filter aswell.and you would be dreaming to include a fuel filter in a service for under 300,if it needs anything adjusted it then turns into a repair. these days a service is an oil change and maybe lube your door hinges if your lucky. then they present you with a list of stuff that needs doing.
matarautrader,
Nov 6, 5:06pm
I use Richard from AMT. Great service and good prices and because hes a mobile mechanic it means I don't have the hassle of getting my car to the workshop.
