Mazda Bounty / Ford Courier Drive/Fan Belt Broke
dinoz, Apr 4, 7:10pm
Hi, just coming home on the motorway and one of the two belts that drives the fan, alternator! and I think air-cond unit broke. Will the car be alright running on one belt until I can get to a garage in the next couple of days! The car is a Mazda Bounty 2002 2.5 Turbo Diesel Ute. Seems to be running fine, but just wanted to ask anyone better qualified. Cheers
franc123, Apr 4, 7:12pm
assuming the remaining drive belt is OK, yes.You need to check this carefully and get it sorted TOMORROW.
dinoz, Apr 4, 7:21pm
Thanks, made a hell of a racket as the belt was flying around the engine bay. I better check it hasn't damaged any hoses etc.
dinoz, Apr 4, 7:22pm
What is the worse case scenario if the other belt breaks! Car will quickly overheat I'm guessing!
mugenb20b, Apr 4, 7:45pm
Spot on! And you don't want to overheat those engines, they need all the cooling they can get.
guest, Sep 14, 3:40pm
Hi Bounty double pulley keeps throwing belt off?
John
