Rust proofing a trailer
jezz43, Mar 28, 6:07am
i just bought a boat and trailer, the trailer is ok but has a bit of surface rust from launching the boat, is there anything i can coat/paint it with to stop seawater corrosion!
chutneyman, Mar 28, 6:30am
Go to Mitre Ten. Buy " Blackguard"$51 per litre !But awesum stuff
wfl1, Mar 28, 6:35am
If you can afford it go to the trouble of getting it sandblasted and hot dip galvanized,paint is only a short term fix.
gammelvind, Mar 28, 6:51am
If you cant afford hot dipped galv., go into your local Autolinkshop, you can get blackguard there for about $30 plus gst, plus any paint required. If you want a more durable finish, ask for PO15 primer which is a rust converter and primer that seals the surface and forms a rock hard surface. Then a coat of paint to cover the PO15 which doesn't have any UV restsance. PO15 about $90per litre plus gst.
spottie, Mar 28, 11:16am
Problem with painting is that it only protects the steel that you can see. Any hollow sections will be quite happily rusting away inside.
Hot dipping from new is the only way to go on a boat trailer as far as I am concerned.
