Cam belt needs to be changed in a few months ( yes water pump and idlers etc ) What dollars should I budget to have this work done!
hijacka,
Mar 18, 11:17am
between $1000-$1500 I only replace the noisey bearings where some replace the whole lot regardless. $400 bearing tensioners $150 cambelt 120 waterpump. Coolant $40.and the rest labour.of course depending where you shop(Ball park)
johnf_456,
Jul 31, 1:55pm
^ as above, hijacka is subaru guru around here.
