Rear wing design
Page 3 / 3
mrfxit, Feb 1, 11:17am
Reverse psychology for a moment .
Wheel standing a motorcycle.
lifting the front suspension is easy (bit of throttle)
lifting the front wheel is a chunk harder (sudden throttle twist)
Holding that wheel stand is a trickybalance (keeping it in the center of balance)
Flipping it over is easy peasy over balance.
Dropping it again is easy peasy over balance
Ok enough of that .
Balance is the key
keeping the total weight in a straight line is the trick.
Once the rear weight center lifts over the fronts center .it adds to the front above the fronts center line.
Stop the back from lifting & the front from dropping.
THEN you can work on the tyres & pressures.
mrfxit, Feb 1, 11:18am
Only possible problem with lifting the front could be drive shaft angles
morrisman1, Feb 1, 11:26am
They are fine when the car is jacked up at the front so I reckon they will be fine sitting on slightly higher springs.
saki, Feb 1, 3:01pm
This may sound stupid but go onto a mini forum they have been racing FWD for years and have got it fairly well right, some have big power twincams as well.
smac, Feb 1, 3:22pm
The trouble is, the advice there will be about how to get a mini to stick (or not stick, as the course requires). What's needed here is advice on getting a car that has been fundamentally changed from it's original design back to something resembling a car that handles. The advice relating to minis will be the same as above though: get your corner weights sorted, get your weight transfer sorted, THEN play with tyres and wheels as required by the particular course.
mrfxit, Nov 28, 3:45am
Think of it like this .
What happens when braking hard on a pushbike from (say .) 40kph & you heave on the brakes .
1: standing up
2: sitting down
(Had a fwd unicycle for 30 seconds or so 1 night like that)
