Could someone help please, I have to remove the horn bar off the stearing wheel, to enable me to sort the springs etc to stop the horn from sounding continuously. Thanks in anticipation, Warren
Feb 12, 5:48pm
Are there any screws underneath the steering wheel that hold the horn button on! Usually, there are two phillips screws, one on each side.
buckyboy,
Feb 12, 6:03pm
Thanks, The first thing I looked for. Sorry, but no screws. I can see screws insideholding the horn bar on but no way to undoo the things. Cheers Warren
Feb 12, 6:08pm
OK, what if you try and pry the horn button off, gently to begin with. Sometimes they are just clipped on.
buckyboy,
Feb 12, 6:16pm
Thanks, I will give it a go. Keep an eye out for much blue clouds .Warren
bus222,
Feb 12, 6:18pm
x1
push the horn down and twist anti clockwise.there are 3 pins on the wheel and 3 slots on horn unit with bigger hole at end.
buckyboy,
Feb 12, 7:07pm
thanks bus222 does wonders with your knowledge.
