my car has started rough idling,the air cleaner is new.Once warmin traffic it just about cuts out.Is this transmission or mayby plugs,Im beside myself with it.Milage isa 157,000 not high but getting like me old.
morrisman1,
Feb 16, 5:05pm
pull the plugs out and make sure they are not all black and sooty. Does it consume oil at all!
Does it do it when warm or cold or both! Does it do it in neutral or in gear too!
You can force the computer to produce any fault codes it has stored so that could be another option to explore. If the computer has detected a faulty sensor or component then it will log it and depending on what has gone wrong it may run in 'limp home' mode where it will run very rich.
petetang,
Feb 16, 5:11pm
No its dose not use any oil at all from one oil change to another. Have not taken plugs out yet , not sure of the right toll. When in drive more rough idling. Not blowing any smoke when you kick down. Thanksso far for your help
morrisman1,
Feb 16, 5:17pm
Idling rough when warm or cold or both! Thats a good piece of information to know when diagnosing
petetang,
Feb 16, 5:32pm
Both
gabbysnana,
Feb 16, 5:39pm
doesnt have a computa.
morrisman1,
Feb 16, 5:43pm
and you have determined this how! It is 1996 so chances are it is injected unless it is a 1.3L model then it may not be but probably still is
petetang,
Feb 16, 5:46pm
its a 1.5L fuel injected
foxdonut,
Feb 16, 5:47pm
A mate had a similar set of issues with his Interplay - culprit was the AFM.
morrisman1,
Feb 16, 5:49pm
Does it run fine at higher rpm and when under load!
petetang,
Feb 16, 5:52pm
Yes runs fine at higher RPM but when in stop go traffic idles rough
Feb 16, 7:32pm
^^^^^^ Idiot.
morrisman1,
Feb 16, 7:35pm
is it a low idle rough or does it idle at a normal RPM while running rough!
sorry about all the questions but I am just trying to build a picture of what is happening in my head
Feb 16, 7:35pm
Clean out throttle body, replace spark plugs, check air intake hoses for splits bewteen the air filter and plenum chamber. Failing that, check for air leaks around the intake manifold. Let us know how you got on.
petetang,
Feb 17, 4:48am
Thanks for that mate will do that Saturday , not good when you have to use it to get to work every day.
trogedon,
Feb 17, 6:23am
You'll probably need a Psychologist to do that MM ;-)
petetang,
Feb 18, 11:39am
thanks for all the help took car in this morning got trans flush and plugs done car running like a dream again , plugs were very black. and trans very dirty.
johnf_456,
Feb 18, 1:46pm
thanks for letting us know how you got on
guest,
Mar 7, 9:09am
Well it seems the problem is still there
