Hi all.Does anybody know the procedure for accessing/removing/replacing the front wiper motor assembly in a 1994 Ford Econovan Maxi! (Same as Mazda E2000 I believe).
Have had a look around, there doesn't appear to be any way in from the outside, it seems like the dash has to come out.
Anyone actually done this!
Cheers.
bigfatmat1,
Feb 19, 12:39pm
x1
you can remove wiper motor from while dash in place. to remove linkages you need to remove dash takes bout an hour to get dash out
saxman99,
Feb 19, 1:02pm
Thanks for that.Do I just have to reach up under the dash next to the door you mean!
