98 coon, for about quarter of an hour the a tappet got really noisey and the car started running rough on and off. Then it dissapperared like there was no problem at all! What gives! Is that an idication that one of the hydraulic tappets/lifters is about to fail!
doomy999,
May 14, 9:59am
and yes, plenty of oil.
a.woodrow,
May 14, 10:05am
Belky is awesome!
bellky,
May 14, 10:08am
Aside the stupid comment above^, I'd like to know the answer too.
jason18,
May 14, 10:08am
I have that in mine occasionally too. Been doin that for a long time haha.
curlcrown,
May 14, 2:09pm
Noisy tappets alone do not effect the way an engine runs. There is another problem there.
xpfairmont,
May 14, 2:36pm
Oil pump might not be working to well! How's the pressure! Has the light come on!
luxlby,
May 14, 2:44pm
It will be noisey and thengo away as the tappet turns
doomy999,
May 14, 3:02pm
oil pressure is fine.
doomy999,
May 14, 3:03pm
If a hydraulic lifter is not working,even if only temporarily, wouldnt that make the car miss and burn more fuel!
doomy999,
May 14, 3:04pm
so maybe its just something coons do now and again.
cheers jason.
ema1,
May 14, 3:04pm
I think taking a look at the condition of the camshaft lobes for wear and for a possibly defective/worn cam follower/lifter might be wise! Something isn't right here, a hands on diagnosis is really required first hand .
bellky,
May 14, 3:05pm
Turns!
msigg,
May 14, 3:29pm
Give it an oil flush and new oil .
doomy999,
May 14, 3:40pm
Its running like a dream at the moment.So am going to wait to see when or if it happens again before doing anything about it. Dont really want to start stripping her down if its not going to come back again.
doomy999,
May 14, 3:40pm
why, what would that do! Besides, been done last week.
unbeatabull,
May 14, 3:47pm
Chuck some Pro-Ma into it. When they start getting to that age the lifters start to get a little noisy, just a fact of life really.
unbeatabull,
May 14, 3:47pm
Was the correct spec oil put back in!
a.woodrow,
May 14, 4:20pm
Nope I agree it was a stupid comment. Do you miss frank!
doomy999,
May 14, 4:28pm
this wasn't a common noisey lifter. Noisey lifters dont make your car run very rough for a short time, then dissappear.
doomy999,
May 14, 4:29pm
I bet he misses being called bubsy wubsy.
skin1235,
May 14, 5:41pm
don't be quite so defensive, and try to understand what a lifter actually does
if the oil flow is interrupted or leaked( read lump of sludge under ball seat ) it will lose the oil it has - and become very noisy for as long as it cannot get or hold oil then when it does finally get oil it may also get a dose of air too, this will actually lift the valve off the seat - (make it run on 5 cylinders ) until that air is displaced and any excess oil is leaked off after that it will run as per normal, ie quiet and efficient
the fact it had an oil change recently could even be the cause of it, the new oil ( fresh load of detergent included) could easily have washed out a bit of gunk that has yet to exit the system to be picked up by the filter next time round
mrcat1,
May 14, 5:57pm
Just chuck a new set of lifters in it, quite easy if you have the gear. But as Skid says most likely because of oil change and disturbing something.
doomy999,
May 14, 6:11pm
Like wise I could say stop being so condesending, but I know that wasnt your aim. Just as my post wasnt intent on being defensive. Was just typing in a hurry. In the old days, it was common for the old falcons, holdens etc to have noisey lifters from general wear and tear.From memory you could just adjust them, or on some makes. Been a few years since I worked on cars. So that's why I was alluding to, its not one of those situations. Your post makes perfect sense and is more than likey the case here. Appreciate the comment skin1235. cheers.
May 14, 8:29pm
What oil filter was put on it! Don't use fram filters in those things, I made the mistake of using one on an EF once and after a week of cold starts and horrible noise for several minutes from cold from the lifters and possibly even the timing chain too it was binnedand a ryco used instead.Problem instantly solved.
