hi, (b16a) is it ok to run a sandwich plate feed to the turbo oil in, and return (from turbo) drain to the sump and use the small bolt by the vtec solenoid as a feed point to a oil cooler and return the oil cooler to the return point on the sandwich plate!
hope that made sense ! any help would be much appreciated
motorboy2011,
Apr 4, 9:22am
oil lubed, not cooled. Use a "T" join where your oil pressure sensor is and run that to your turbo oil feed, drain to sump.
bellky,
Apr 4, 9:27am
I'd say the oil exiting the turbo is a higher temperature than the oil entering.
thegravelracer,
Apr 4, 9:33am
I was meaning having a oil cooler aswell
thegravelracer,
Apr 4, 9:34am
and ive heard the oil pressure sensor point has to much fluctuation for a turbo oil feed thats why im using the sandwich plate as a feed
Apr 4, 10:18am
So! It still has bearings.
bellky,
Apr 4, 10:19am
I'm aware of that thanx
Apr 4, 10:21am
It didn't sound like it.
bellky,
Apr 4, 10:21am
Doesn't matter.
happylad3,
Apr 4, 12:50pm
Workmates car (dc2 Integra, with 675hp at front wheels) he just said he takes the oil feed off the main gallery, and tees into the oil pressure switch.
