1987 L300 van
morrisjvan, May 17, 7:12pm
Hi all , have got a mitsy L300,2lt ,5 speed ,column change . sometimes,(and getting more frequent), it wont go into reverse ,when it does go in it is as good as gold, no graunching, no noises, andsmooth change,but when it plays up it just dosent want to go.! is this a common problem !
pettal, May 17, 7:24pm
Have you tried giving the linkages a lube ! .
matthew_129, May 18, 6:56am
Your not shifting into 5th and then reverse by any chance! Most manual gearboxs will not allow a 5th to reverse shift by locking out reverse gear.
yogibearz, May 18, 7:11am
There is a selector linkage in the box for reverse gear which can jamb and cause no reverse gear selection. I have seen a few on high mileage rural delivrey vans with the fault.It can be replaced with out removing the box but i cant recall the cost of parts. To a dealer who has done it before its not a big job but it is a bit fiddly .
morrisjvan, May 18, 8:52pm
the linkages move freely,don't think it's that.
morrisjvan, May 18, 8:54pm
dosen't seem to matter which gear i'm in previously, sometimes it goes, sometimes it don't.
morrisjvan, May 18, 8:56pm
That's bound to be the problem. good that the box dosent have to come out though !
gizmsme, May 18, 9:14pm
Does that model have the cable behind the front bumper that adjusts the sweep to select reverse! That and the pivot arm bush were the most common problems I came acrossand both easy to check.
mugenb20b, May 19, 8:38am
Yes, but it takes only 15 minutes to remove the gearbox.
