Anyone know where this is located!Have looked in all the usual places under the dash and underbonnet areas and can't find it anywhere, google hasn't revealed anything either.Its a PM11 series with an SR20DE in it if that helps, and no it's not in the fuse box like Primeras generally are!TIA
jono2912,
Jul 1, 10:39pm
I know the 97 pulsar has one just above or below drivers fuse box, although that had a SR18DE in it.
The 1990 P10 have it in top right engine bay.
ceebee2,
Jul 2, 2:46pm
Its in one of three places I can think of for most Nissans although its been awhile Glove box Under bonnet LHS firewall Steering column under the cowls.
Jul 2, 2:59pm
its either obd2 or the nissan consultdata conector.
bubbles52,
Jul 2, 3:09pm
pull out the ashtray
Jul 2, 4:54pm
Hmm, there is a plastic panel that is held by four screws directly under the upper part of the steering column, I can't see anything underneath it but will remove it anyway to be sure.You wouldn't think they'd make it that inaccessible though!It's definitely not behind the glovebox, ashtray or the console fillet plate directly under the handbrake lever as they sometimes are. Thanks for the input everyone.
jasongroves,
Jul 2, 4:57pm
Weird that its not in the fuse box! Another common Nissan trick is to have to get to the ECU itself, mounted on the tranny tunnel and flick the switch to get codes. That may only be on older models though but might be worth a look.
supertech1,
Aug 19, 9:55pm
97 OBD Na!consult data conector
