gidday there i have a problem with my 1.8 injected auto 1989 corona. It will just cut out when driving along. it starts perfectly fine and run sweet will sit there and idle all day but seems to be dying when put under load. does anyone know of this problem or had experience with these! cheers
jmma,
May 28, 7:18pm
When it cuts out, does it restart straight away!
jmma,
May 28, 7:19pm
Could be blocked fuel filter
jasongroves,
May 28, 7:23pm
Fuel pump could be worth a look too.
printerhunter,
May 28, 7:32pm
yeah restarts straight away cheers
ema1,
May 29, 5:54pm
I would be inclined to agree with Jase on this one, had a similar problem on a GX61 Cressida Grande years ago grabbed a pump off a wreck and problem solved for another 100,000km until I sold it.
carclan,
May 29, 6:23pm
Check the ignitor, sounds like that kind of fault.
kcf,
May 30, 9:10am
Check the ignitor, I had a 4age Corolla give that symptom.
It would cut out under any load, but would idle perfectly happily.Then of course it was an intermittent fault, so took ages to actually diagnose.
gadgit3,
May 30, 1:59pm
Bad earth to coil / ignitor.
