Towing capacity appears to be 2000 pounds - so about 900 Kg.
Which doesn't seem much, so I presume is unbraked.
dunn28,
May 27, 2:24pm
900 kg maybe the static weight eg when the weight is applied directly down ,towingcapacity will also be determined by the type an rating of the tow frame
faa_luke,
May 27, 3:23pm
If going automatic you'd want a transmission cooler. Apart from that I can't help much. Going by the above specs though it doesn't have a huge amount of torque so could be working pretty hard wit hard with a big load.
