Looking at buying my son the above car off a mate at work,car is regularly serviced & he has owned for last 18 years,only thing is it has done 318000km & cambelt is due,anyone know how much for cambelt to be replaced!It is a 2 Litre NZ new.
icemans1,
Jun 2, 11:13pm
are you sure it has a cambelt and not a chain!
strobo,
Jun 3, 1:49am
#2 The CA engine is a 1.6 L to 2.0 L Inline-4 piston engine from Nissan designed for a variety of smaller Nissan vehicles to replace the Z engine and some smaller, four-cylinder L series engines. It is an iron block, aluminum head design with a timing belt, thus was cheaper to make than the timing chain setup on the Z and L engines. Earlier versions featured SOHC and eight valves. The new CA block design was a scaled up E series block with timing shaft and other ancillaries removed. The oil pump is fitted directly onto the crank nose and the distributor is driven by the end of the camshaft. Like the E series and the A block from which the E was derived, Nissan used a taller block for the largest stroked 2.0 litre engine. The CA was designed to be compact and light, with a CA16 requiring only 195 litres of space (compared to 280 litres for the earlier Z16), while weighing 23% less at 115 kg (254 lb). The SR engine is the chain drive one.
strobo,
Jun 3, 1:49am
strobo,
Jun 3, 2:07am
The Nissan SR engine is a 1.6 L, 1.8 L, or 2.0 L straight-4 4-stroke internal combustionengine . It features an aluminum head and aluminum block with steel sleeves in selected models and features a DOHC 4-valve design, with variable valve timing on select models. The engine was used in many small to medium Nissan vehicles, including high-performance turbocharged variants. It was designed by Nissan as a replacement for the earlier CA series of engines. The posters is the CA engine "nz new"
strobo,
Jun 3, 2:07am
Best to drive into ( NOT RING)at least3 different renownedgarages preferbly that have trade qualifiedpeopleor MTAmembers NOTEtheir comparable quotes or estimates .
Jun 3, 7:35am
Allow $300 for a cambelt replacement only. It will cost a bit more to replace the tensioner, seals and water pump should you choose to get them done at the same time.
likit,
Jun 3, 1:58pm
Thanks,didn't want to be hit with a huge bill considering car is cheap.Cambelt has only been replaced once at 220000km as owner thought it had a chain.
