steel rim or alloys! rest wont matter what car. but if you do 8 kg this is the normal torque load that i use on all rims unless they are magnesium there you got to be more carefully.
andrac63,
Jul 13, 3:35pm
alloy rims
Jul 13, 3:38pm
do 8kg be ok max 8.5 its if i recall right 80NM to 85NM normal alloys will be ok like this considering that most people use a brace when they change a tyre on the road side. after 50km you recheck the nuts. its what all tyre places write on the sales sheet in europe when they fit new tyres
Jul 13, 3:46pm
The correct wheel nut torque for those is 125Nm, anything between 100-150 is acceptable.
Jul 13, 3:56pm
that be 12.5kgto 15kg
im_andrew,
Jul 13, 4:01pm
110nm is what I use for normal 12mm car wheel nuts
Never heard anyone use KGs as a unit of torque before.
unbeatabull,
Jul 13, 5:47pm
135n/m is correct spec, and I work at a Ford Dealer so should know :)
woody1946,
Jul 13, 6:04pm
Tell that to Tony's Tyre Service, bent the factory brace trying to get wheel nuts off, had to borrow a socket and bar in the end
monzaman,
Jul 13, 10:05pm
Mercedes 12mm wheel bolts 110nm and 14mmwh. bolts 150nm for example.
jrlaw,
Sep 9, 6:13am
Do them up till stripped then back them off two turns. That should sort it out!
