Just replace belt on E36 320i but can't get tension on it, can anyone help please!
Aug 7, 2:05pm
Serpentine belt!
buzzin89,
Aug 7, 2:12pm
Yes, tensioner pulley now out and seems fine Belt size is correct 6PK1555
Aug 7, 2:22pm
Have you got it on the right way!
buzzin89,
Aug 7, 2:30pm
Haha yep according to friend google everything is correct Is there any adjusters on alternator or powersteer units!
rovercitroen,
Aug 7, 2:48pm
Is the belt the correct length!
srrolla76,
Aug 7, 2:53pm
is the part number the same as on the old belt! on most cars there is a tensioner on alternator etc. check too see if all the tensioners are done, u may need to back the other ones off a bit, and tighten up the others (if any) in order to get it right tho
buzzin89,
Aug 7, 3:08pm
Got belt from repco, 6PK1555 Supercheap list same belt
buzzin89,
Sep 18, 5:16am
Yep seen all those and other diagrams so can't see why there is still not enough tension, have even taken belt back out to check numbers on it incase not packaged correctly.
