Im sure it didn't do this before but the last couple of times I've gone to drive it when i get in it's been beeping at me it stops a few seconds after I've turned the engine on have been careful lights are off etc . I had a flat battery a few weeks ago so I may be paranoid but it only gets driven at the weekends and the battery seems fine after I charged it all night as was to scared with the computor to jump start it320 I. 2002is this normal !Thanks
jason_247,
Jul 7, 9:02pm
not sure about 3 series but my five series beeps at me for a few seconds in the morning and flashes theext temp
this is only if its below 3'c to warn you of potentially icy roads
the-saint1,
Jul 7, 10:04pm
It always amazes me the misinformation and misunderstandings propagated whenever someone lists a series of symptoms, then expects an accurate answer even though the correct diagnosis will only be reached after a skilled and experienced technician is able to assess the problem with the car in the workshop and all diagnostic tools plugged in.Phewww!
s.c,
Jul 8, 7:08am
Why should I take it to a mechanic and get charged when it may be something simple and some one on here knows what it is and if it is serious I can then take it in to be looked at it only does it when starting for a few seconds
doriandarby,
Jul 8, 7:54am
First thought I had was - is it the seat belt reminder beeping!
NZTools,
Jul 8, 7:55am
Because any diagnosis you get on here is only going to be at best a guess, based on the very vague infomation provided about the symptoms, which could represent any number of faults.
fourkingz,
Jul 8, 11:43am
Join the NZ Bimmersport website, and ask in the forums.
gunhand,
Jul 8, 11:50am
Well ya wrong. I listed a buch of symptoms here a while back that i already new the answer to to "test" the knowladge on here. Within 30 mins the correct answer was givin, post 3 I think it was. So there are some who know what there on about. And do do most mechanics start with! a bunch of symptoms.
fiatracer,
Jul 8, 12:35pm
my BMWs both beep at me now too - the sub-3 degrees warning - I bet the external air temp flashes up too
s.c,
Jul 8, 5:24pm
Thanks turned out it was the seat belt. What a great site for BMW fans
