Bump, I hoped we had some alarm experts on this MB!
bigfatmat1,
Aug 1, 7:04pm
Not all switches are labelled the same! but answer to your question. Do you want a bypass switch so you still have imobiliser! or do you just want to bypass it the switch would need to be rated to 20a.
sr2,
Aug 1, 7:22pm
I thought I'd use a hidden switch so I could still use the immobiliser. The relay is rated at 20 amps into a resistive load and I was planning on using a similarly rated switch. We??
bigfatmat1,
Aug 1, 8:03pm
The way you suggest will work fine. I have seen the v2600 at repco for $160 much better alarm than the v1600
sr2,
Aug 1, 8:40pm
Thanks mate, I'll have a look.
